Posted: May 14 2008 at 6:13am | IP Logged
A small change resulting in a taller "gear" is to go from 265/70 tires to the 265/75 tires that are, I think, on the Nismo. You'll do a a few less tire RPMs per mile which might help your mileage. But keep in mind that tire weight may go up. You'll notice "taller gears" when towing or going up long grades as well. Use the calculator below; you'll save about 20 rpms/mile on the tires which is about 3%.
Mopar Register: Tire size and RPM calculator
