Subject Topic: Pics 05 Fronty w/ E&G Grills Post ReplyPost New Topic
JBoat
Posted: Sep 22 2005 at 7:38pm | IP Logged Quote JBoat
I ordered these through ASD on EBay.  It took them 3 tries to send me the correct parts,  but I finally got the right stuff.  It seems I may have a LE lower bumper according to them.  They said that the SE has the wider opening than the LE does.  Mine has the narrower of the 2.  Can someone confirm the differences between the 2 lower bumper openings.  If this is true then Nissan did indeed install a LE bumper on my SE.  FWIW ASD did provide great customer service and went above and beyond to get me the right stuff.  They even sent me the replacement parts 2nd day air and called to confirm I got them...
Oh well...It looks good.  Here's a couple of pics...
2005 Black SE Crewcab 6sp.
Back to Top View JBoat's Profile Search for other posts by JBoat
JBoat
Posted: Sep 22 2005 at 7:40pm | IP Logged Quote JBoat
AZLS1
Posted: Sep 23 2005 at 10:30am | IP Logged Quote AZLS1
Looks good.   Do you have firetruck sirens in your bumpers where the fog lights go?
Back to Top View AZLS1's Profile Search for other posts by AZLS1 Visit AZLS1's Homepage
JBoat
Posted: Sep 23 2005 at 12:30pm | IP Logged Quote JBoat
...WOOOooooo,  WOOOOooooo,   Puuu  Ova...Puuu Ova!!! (Eddie Murphy)
Some stupid plugs that Nissan put in where the fog lights were supposed to go...I may have an LE bumper so maybe it will be an easy upgrade to add them later...
chriscscs
Posted: Sep 23 2005 at 1:00pm | IP Logged Quote chriscscs
I have an SE as well, it looks like your bumber is the same as mine.  Except that I have four or five plastic slots that run up and down in the area that your guard is, or does the guard cover these slots?.  And upgrading to fog lights was no problem in my SE, should be the same in both SE and LE bumpers.
Back to Top View chriscscs's Profile Search for other posts by chriscscs
JBoat
Posted: Sep 23 2005 at 1:06pm | IP Logged Quote JBoat
Did you do the foglights yourself?  Was the wiring harness already there?  Can you maybe list the parts that you used?  I plan to do this next and would like to know what I'm in for.  Can you use them without the headlights on (running lights only)...Or if there is a link to somewhere that show this I'd appreciate it...Thanks
redwlf1971
U.S. - Arizona
Posted: Oct 01 2005 at 6:37pm | IP Logged Quote redwlf1971
On My nismo the foglights came with it and they only work with the lights on and the brights off.
Back to Top View redwlf1971's Profile Search for other posts by redwlf1971 Visit redwlf1971's Homepage
