sams2000tier Newbie
Posted: May 19 2007 at 4:31pm | IP Logged
i have a 2000 frontier with 31x10.5 bfg all terrains and i want to put
33x12.5 bfg all terrains on it how much of a body lift would i need for
them to fit without rubbing? and where could i find a kit thats not so
expensive?
jrknsrk Newbie
Posted: Jul 05 2007 at 1:24am | IP Logged
For your first question you would need to go with a three inch body lift to fit the 33's. You can find the kits all over, that is not the expensive part (only about $100) its the install that is expensive ( a couple hundred if done by yourself). I find it better to put an actual lift kit on your truck rather then doing a body lift because a lot of the time you will spend about the same amount of money. Automotive Customizers out of florida have a descent 3" lift that only include swapping out the upper arms for about $300. I have also had a rough time finding things for my 2000 nissan frontier. There is not much out there but if you have some money and depending what you want to do to your rig; check out Total Chaos Fabrication I have their kit on my rig and it is amazing! Well take care and good luck! If you have any questions email me at inlovewithjc98@hotmail.com
sams2000tier Newbie
Posted: Jul 18 2007 at 12:49am | IP Logged
well i have a buddy of mine that will do it for me but i just need to find the
right kit for my truck i cant find one anywhere i have a 2000 desert
runner extended cab 2wd any help would be appreciated
hintonl Senior Member
Posted: Jul 18 2007 at 9:04am | IP Logged
Try searching the fourms here there are at least 5 differant posts
sams2000tier Newbie
Posted: Jul 18 2007 at 10:51am | IP Logged
well i found a 3 inch body lift kit for a 2000 desert runner but its for 4wd is
there any way that would work for a 2wd
Posted: Jul 18 2007 at 1:47pm | IP Logged
The Desert runner was never made as a 4X4 its call a Desert runner because it sits on a 4x4 frame its basicly a 4x4 with no drive train.
sams2000tier Newbie
Posted: Jul 18 2007 at 4:58pm | IP Logged
well that helps alot haha i appreciate it
