Subject Topic: 05 Frontiers lift kits/ cold air intake Post ReplyPost New Topic
cartier
Posted: Jun 27 2005 at 12:24pm | IP Logged Quote cartier
Has anyone out there lifted an 05 crew cab 4x4 frontier? i found lift kits from rancho but there only 2.5' and thats just not going to do it. and also im looking for a  cold air intake and a high performance exzaust for my frontier
Back to Top View cartier's Profile Search for other posts by cartier
Posted: Jun 27 2005 at 7:39pm | IP Logged Quote kcidmil
welcome to the org.  intakes can be found here www.4x4parts.com not quite sure if the lift kits found there will fit the new trucks.
As for exhaust... it's actually cheaper to go out and have a shop put 2.5" piping, your choice of muffler and tip(s).  You'll get about the same performance as a cat-back and half the cost.
btw... this should be in the modifications section... I went ahead and moved it.
Joehova
U.S. - Colorado
Posted: Jun 30 2005 at 1:20pm | IP Logged Quote Joehova
I have found a front leveling kit from stillen so far, as far as the 05 is concerned... I don't know if I would put a rancho kit on my frontier... if the kit has come out that fast then it hasn't been tested the way it should be. Total Chaos Fab is working on their 4x4 long travel kit but it won't be available for a few as they like to trash their trucks to see what needs to be improved on their parts. As far as an intake goes, I've only found a K&N drop in filter for my fronty. Also, with my truck I had custom pipes set up with a flow master and the exhaust dumps just before the rear tire. Looks pretty cool and really improved the performance on the top. After I set up the truck with the drop in filter, the void of power was filled on the bottom. Not to mention I spent a whopping $250 for my exhaust... hell of a lot cheaper than a gibson or some other after market exhaust that may not fit right.
---Joe---
05 NISMO 4x4
Back to Top View Joehova's Profile Search for other posts by Joehova
JBoat
Posted: Jul 26 2005 at 12:46am | IP Logged Quote JBoat
This sound very interesting indeed...11HP and 15FT# torque...
http://www.afefilters.com/frontiereview.htm
2005 Black SE Crewcab 6sp.
Back to Top View JBoat's Profile Search for other posts by JBoat
