Drunkjam Newbie
Posted: Apr 14 2016 at 8:06pm | IP Logged
I am selling four new Level 8 Bully Pro.
Size 16 X8.5 6-114.30 -6 BKMEXX
Diameter 16″
Width 8.5″
Bolt Pattern 6-114.30
Finish PRO BLACK
Level 8 Wheels Bully Pro is a wheel
deigned by off-roader for off-roaders. It
is a slim, 8 spoke wheel design in Level 8
Wheel's Pro Series line. This wheel
features a bolt-on lip protector ring,
durable three stage Pro Black finish, dual
valve stem setup for easy air up/air down,
and a specially designed bead hump to keep
the tire on the wheel during your off-road
adventures. The wheel is low pressure cast
aluminum construction which is designed to
be lighter and stronger. It has "LEVEL 8"
and "PRO" cast into one of the spokes of
the wheel to set it apart from imposters.
The Bully Pro is built specifically for
your lifted/leveled Jeep, Truck, or SUV
and will navigate any off road terrain.
