Frontier Off Road 4x2/4x4
Subject Topic: Need a rear locking Differential... Post ReplyPost New Topic
IdleOne
Posted: Oct 20 2006 at 4:41pm | IP Logged Quote IdleOne
I have a 2002 Desert Runner. It handles its own (for being a 4x2) off-road. I could really use a locking rear diff. what do i have to do?
Thanks in advance...
Back to Top View IdleOne's Profile Search for other posts by IdleOne
blackmagicx
Posted: Oct 20 2006 at 4:49pm | IP Logged Quote blackmagicx
you should try 4x4parts.com
2001 Nissan Xterra SE
Calmini 3" Suspension Lift
Automive Customizers 2" Body Lift
Spencer Low Racing Steering System
Back to Top View blackmagicx's Profile Search for other posts by blackmagicx
hintonl
Posted: Oct 21 2006 at 8:31am | IP Logged Quote hintonl
Have about 800.00 for An ARB air locker they are the only MFG only you can get/use as your rear axles are 33 spline. Then about 250.00 for the compressor then about 250-300.00 for a rear end shop to intstall it and hope they did it right unless you know how to set it up.
2K Crew Cab Converted to 4X4
IdleOne
Posted: Oct 21 2006 at 12:06pm | IP Logged Quote IdleOne
Thanks guys... cost a little more than i am willing to spend, I just need to buy an 07' 4x4
blackmagicx
Posted: Oct 22 2006 at 3:54pm | IP Logged Quote blackmagicx
you can also get a mechanical locker thats like 400 like powertrax or something similar and about 300 for install.
hintonl
Posted: Oct 23 2006 at 8:34am | IP Logged Quote hintonl
Please tell me Where you can get a Mechinical Locker at  for a 33 spline rear axle
blackmagicx
Posted: Oct 27 2006 at 2:28pm | IP Logged Quote blackmagicx
 you could go with a replacement of your 33-spline axles with some older 31-spline Nissan axles (you are looking for ones with Drum Brakes and ABS, older Frontiers are the best bet), and then you could go with a Lock-Right or Detroit locker. Check out: 4x4parts.com mechanical lockers
these are for 31 spline
http://www.rocky-road.com/lockright.html
http://cgi.ebay.com/ebaymotors/Lockright-locker-Nissan-Xterr a-Pathfinder-pickup_W0QQcmdZViewItemQQcategoryZ33731QQihZ019 QQitemZ7996972100QQrdZ1QQsspagenameZWD1V
IdleOne
Posted: Oct 27 2006 at 2:30pm | IP Logged Quote IdleOne
I just bought a 06 crew cab nismo... pics soon
hintonl
Posted: Oct 27 2006 at 4:03pm | IP Logged Quote hintonl
For what it would cost you to do the conversion to 31 spline axles you might as well just put in the ARB and be done with it.
hintonl
Posted: Oct 27 2006 at 4:05pm | IP Logged Quote hintonl
Cool  I have been looking at the new X ant the new Frontier as a tow vechical I am going to turn my Frontier into a trail rig in the next year.
Page of 2 Next >>
