Posted: Oct 31 2011 at 10:23am | IP Logged
All good advice above!! I've driven 4WD for decades and the advice about never using it on dry roads is spot on. Your truck does not have a differential action between the front and rear axle so when you go around a turn in 4WD, the wheels are required to slip. This works just fine in snow, ice, muddy roads, gravel but cannot work on dry roads. Eventually something will break.
Also,Don's note about getting twice as far before getting stuck is very true. 4WD can tempt the novice (and the experienced driver) into going further into a mess than is safe. It is easy to drive too far into deep snow or mud and then realize that even with 4WD you cannot get out. So learn by driving. test your truck in slightly muddy or snowy area. Make sure the tires that you have on the truck are the right type. I use Cooper Discoverer CSX that are a mild tread. I hunt and am generally on gravel roads with some mud and snow. For this, they are fine. But they would NOT get me in or out of heavy mud or snow.
ALso remeber that you nheed to maintain 4WD regularly. This means drianing and refilling the transfer case and both diffs. Learn to do this yourself and use qulaity fluid. Always remember to remove the fill plug before the drain plug! I use Mobil 1 75W-90 in my diffs with very good results. I change it at 30,000 miles after an initial drain and fill at 5000 miles to get out the metal from break-in. The tranfer case requires ATF. Nissan dealers carry the washers you'll need to do these jobs.
And remeber NEVER drive across a steep slope. This is an invitation to a rollover.
