MUD DOBBER Newbie
Posted: Feb 10 2011 at 10:28am | IP Logged
can anyone tell me who,what,when or how this can be achieved???Any help on this subject would greatly be appriciated
__________________ MUDD DIGGA
Posted: Feb 10 2011 at 7:28pm | IP Logged
Anything is possible w/ enough time and $$$$$. What
vehicle??????
Bras Newbie
Posted: Jul 14 2011 at 6:23pm | IP Logged
Not sure what year your truck is but it would most likely be cheaper to get a different truck. You will need the trans and most likely a bell housing not sure if they are different on the frontiers, master and slave cylinder, most of the time you have to change the ecu as well. You have to change the center console to fit the new shift level you will as need, and a clutch paddle. That is just a very rough run thought of what you will need, it isn't an easy job. I was going to do it on a camaro I had but didn't really have the time or the money at the time. Good luck tho hope you get it figured out.
__________________ 03 Frontier XE-V6 3.3L 5 speed trans.
