Subject Topic: Gas cover door doesn’t stay closed Post ReplyPost New Topic
Hugh B
Canada
Posted: Nov 24 2006 at 12:56pm | IP Logged Quote Hugh B
It's -10C up here and my gas cover door sort of stays at 1/2" open and is loose.  It doesn't have a positive closed position. I'll be taking it to thje dealer for first check up perhaps in Jan but thought there might be a simple fix.
Hugh
06 Crewcab LE leather
'00 Audi S4 6sp
Back to Top View Hugh B's Profile Search for other posts by Hugh B
Brook724
U.S. - Maryland
Posted: Nov 26 2006 at 7:03pm | IP Logged Quote Brook724
Make sure the gas cap tether isn't in the way, pushing it open.  That happened to me.
Back to Top View Brook724's Profile Search for other posts by Brook724
kegjeg
U.S. - New York
Posted: Nov 27 2006 at 5:14pm | IP Logged Quote kegjeg
There is a recall on the gascap cover. the spring comes loose, you can snap it back on yourself but the dealer has a recall for it and will fix it for you
Nathan Garrant
Back to Top View kegjeg's Profile Search for other posts by kegjeg
