Subject Topic: by pass guvaner Post ReplyPost New Topic
Shook
Posted: May 06 2005 at 8:53am | IP Logged Quote Shook
i have a 2004 frontier and it stop,s me at 102mph and it start,s to lag at about 75mph i do a lot of long driving in Texas an i like to tack advantage of the open road i had a 1997 d21 and it top out at about 125 and ran a 15.88 in the quoter and i know the ka24 in my new truck can bet that sow if some one know how to by pass a guvaner i would love to know to because i think the best part of my truck is the back and i like to sow it to people as i roll on by if you don't know what a ka 24 is it is a in lin 4 16v throttle body inj
Back to Top View Shook's Profile Search for other posts by Shook
Posted: May 06 2005 at 11:55am | IP Logged Quote kcidmil
WOW... they really started screwing you guys.  Actually, you have the KA24DE motor... same motor put in the last gen of the 240sx.  I know, cause I got an 02 with it.
I'm kind of surprised on the 102.  I was able to get 105-8 bone stock.  And didn't start to lag till about 90.  But of course, I have a bed cover.  Either drop  your tailgate, or have a bed cover installed.  It does wonders to fight against drag.
Try these first.  Upgrade your intake.  The KA motors are really strong, you just have to give them A LOT of air.  I was able to push 110 just by dropping in a K&N filter.  A intake from weapon-r or AC will probably help out a lot.
Check out my cardomain site.  There's a little example of a "ghetto" intake on there.  Basicly you remove your air box, and turn the tubing for the box-fenderwell around and attach it to your intake pipe.  You'll have to tape it... but some spray paint hides that.
Also, do a little exhaust work too.  I threw on a Ravin Muffler, and it pushed me a little past the 115 mark.  Also, lag doesn't show till around 104 now.  It's not so much the govenrer, but the lack of free flow.
If you can't seem to get beyond that... Jim Wolf Technology ECU.  Cause the governer is the ECU.  So the only way to get rid of it, is to reprogram.
Shook
Posted: May 07 2005 at 8:23am | IP Logged Quote Shook
I have a k&n in it but it gave me more power but i still stop at 102 i have fond a lot of stuff fore the truck but nuthing that i have fond tels about by passing it i have fond a drag Chip that will add 20 hp but no ecu reprogrammer i know where to get a turbo and i know that it will add 110hp put all that is a wast with out a way around the governor i am going to but headers on to but i dont want people to look at my truck and know that it is fast sow i am not sheer about the header yet cop's like to mess with you if you look like a street racer abut the are box what did you Dow with the senser in it ore did your 02 have one
Posted: May 08 2005 at 2:22am | IP Logged Quote kcidmil
People can't just look at the truck and go... it's got headers.  Neither can a cop.  Sound is a dead giveaway.  But if you go "that's just the muffler I put on"  they'll have no clue at all.
And my bad on the ECU... it was the KA24E motor I was thinking about.  Hopefully they'll come out with one for our generation.
Mine only had the Air temp sensor on the little elbow.  I just kept it hooked up, worked out perfect.
