Subject Topic: 03 a/c switch override? Post ReplyPost New Topic
2003 sc
Posted: Oct 10 2006 at 8:10am | IP Logged Quote 2003 sc
you must have noticed once you switch to defrost the a/c compressor comes on and stays on even if you switch back to any other setting. dealer and service manual both say this is normal. but i dont want compressor running all the time.
has anyone wired an override or shut off for the compressor on their truck
Back to Top View 2003 sc's Profile Search for other posts by 2003 sc
JPNNH
U.S. - New Hampshire
Posted: Oct 20 2006 at 2:56pm | IP Logged Quote JPNNH
I think if you turn the fan switch to off position the AC will stop running but you then must rely on the speed of truck to keep air moving thru the vents until you do a restart of engine to reset the AC switch...
Back to Top View JPNNH's Profile Search for other posts by JPNNH
JPNNH
Posted: Nov 10 2006 at 3:33am | IP Logged Quote JPNNH
I was wrong...the AC still runs...Anyone got a fix for that...It just burns more gas for no reason!
