Gumbo Newbie
Posted: Nov 07 2017 at 8:30am | IP Logged
Any one had an issue with not being able to remove key from ignition switch? Happen yesterday, truck absoluty in park (auto trans) and could not remove the key. Tried puttin it in nutral, starting it, put it back in park and was able to remove the key, but I can see this to be a issue it out and about and not be able to remove the key.
Any ideas??
__________________ 2016 Frontier 2WD King Cab I4
Posted: Nov 07 2017 at 3:09pm | IP Logged
They don't want you to leave the truck and not be in Park.
I don't know if it's a computer issue or mechanical lock out.
So a computer sensor or mechanical adjustment
I'd look at the base of the shifter.. Don S..
Rubble Moderator Group
Posted: Nov 19 2017 at 11:16am | IP Logged
remove key from ignition switch?Happen yesterday, truck
the key. Any ideas?? |
Did you try turning the steering wheel just a little one
way or the other? Sometime's that is needed to remove the
key.
__________________ Barney
