davidjbrady Senior Member
Posted: Feb 06 2014 at 10:44pm | IP Logged
Does anyone happen to know if the auto tranny on a v6 2008 4X4 tourque converter have a drain plug?
I see that there is an access plate to the torque converter but wanted to know if it can be drained?
Thanks!
David
Posted: Feb 10 2014 at 7:45pm | IP Logged
No. It would be best to get it flushed or do it yourself
if you can do it w/o making a mess.
Posted: Feb 10 2014 at 9:41pm | IP Logged
Thanks Frontierguy.
I had planned on dropping the tranny pan and replacing the fluid. Think that's sufficient? Any other suggestions on self flushing kits?
Thanks again,
David
Posted: Feb 11 2014 at 7:17pm | IP Logged
I've heard it can be done by removing a cooler hose and
placing into a container, while filling thru the fill
tube.)with engine running) If you could add some hose so
it would be possible to drain from a hose and fill from
where that hose was attached would be the ideal way if I
didn't have a flush machine. It seems like it would take 2
people to be able to replenish the system as it empties.
