Subject Topic: steering column vibration Post ReplyPost New Topic
ridgevilleguy
Posted: Feb 05 2014 at 8:30am | IP Logged Quote ridgevilleguy
2012 Frontier king cab 4x4, I get a vibration in the steering column noticeable at low speeds,5-15 mph. I never had this problem with my 2010 Frontier. Has anyone else noticed this vibration? It's annoying.
Back to Top View ridgevilleguy's Profile Search for other posts by ridgevilleguy
Posted: Feb 05 2014 at 9:59am | IP Logged Quote lakota
I’ve had several low speed vibrations in my lifetime The
last was two defective BFG AT KO 31x10.50x15s I bought
at
a big name 4x4 shop and they never made good on them. I
ended up buying two more good ones at Costco. I had
another On a Sentra that was out of round after 10,000
miles and might have blown later.
Jacking the truck and spinning the tires will show if
they’re out of round but not a defect.
Have a warm one.. Don S..
2004offroad
Posted: Feb 05 2014 at 6:05pm | IP Logged Quote 2004offroad
what tires do you have? stock suspension? how many miles?
04 frontier 4x4
3 inch lift
ac upper control arms with ball joint spacers
hd tie rod and idler arm brace
rancho 5000
32s on procomp wheels
flowmaster duels
Back to Top View 2004offroad's Profile Search for other posts by 2004offroad
ridgevilleguy
Posted: Feb 06 2014 at 1:28pm | IP Logged Quote ridgevilleguy
Truck has 25,ooo miles, I noticed the vibration after only
a few thousand miles. Stock factory 4x4 tires.
Posted: Feb 06 2014 at 6:43pm | IP Logged Quote frontierguy
After 25K you are worried about it??? Did you ever take it
back to the dealer to get checked? By now, it will most
likely need tires, unless you drive like
"Boomer"!!!!!!!!!!!
ridgevilleguy
Posted: Feb 06 2014 at 8:25pm | IP Logged Quote ridgevilleguy
tires are in excellant condition, they'll go another
20,000 miles. Last time I took it in to a Nissan dealer
technician changing the oil put air in my tires, all my
tires have bright green valve stem caps. Would you trust a
dealer after that?
Boomer
Posted: Feb 09 2014 at 8:59am | IP Logged Quote Boomer
Hey, us old guys can really stretch a buck, Frontierguy!!!
2007 Nissan Frontier SE 4X4
Posted: Feb 09 2014 at 10:04am | IP Logged Quote lakota
they'll go another
trust a
dealer after that?
Yes... And I would thank them.
When I bought my last BFG KO ATs at Costco they put
Nitrogen in all five tires and green caps to note that
there was nearly pure Nitrogen in them.
And yes there is Nitrogen in the air but the Oxygen in
the air will leak out of the tires faster than the pure
Nitrogen.
There have been arguments about the subject but I did not
have to add ‘air’ to my tires for five years.
BTW… don’t put Helium in your tires because it will leak
out much faster than Oxygen!
Posted: Feb 10 2014 at 7:44pm | IP Logged Quote frontierguy
The older we get, the harder it is to find a buck to
stretch!!!
