Subject Topic: noises in 2006 Frontier ??? Post ReplyPost New Topic
noahinBR
Posted: May 26 2006 at 9:08pm | IP Logged Quote noahinBR
1.) a light rattling noise near glove compartment when the truck is moving (and radio is turned down and
2.) a "clicking" sound at the engine after I've stopped.  Almost sounds like pings and knocks.
Does anyone else have this?  My Frontier is only a 2months old, but these are some noises I wasn't expecting.  I wonder if this is just part of the reak-in period.  Any suggestions are SO completely welcome.  I don't want to bug the crap out of my dealership's service department...
Back to Top View noahinBR's Profile Search for other posts by noahinBR
jeff
Canada
Posted: May 28 2006 at 2:27pm | IP Logged Quote jeff
the rattle in around the glove box, annoying, is there a cure? other small
rattles as well. glad to see i'm not the only one though.
Back to Top View jeff's Profile Search for other posts by jeff
06fronty4x4
Posted: May 28 2006 at 7:32pm | IP Logged Quote 06fronty4x4
I dont know about the glove box knock, but the noise the engine is making is because of thermal expansion/contraction.  It makes the same noise when you first start it too, if you listen carefully.  Im guessing it might have something to do with the exhaut being steel and the engine being aluminum, different expansion rates.
Back to Top View 06fronty4x4's Profile Search for other posts by 06fronty4x4
babytitan
Posted: Jun 03 2006 at 9:34am | IP Logged Quote babytitan
the servos in the abs open and test when you hit the 15 mile per hour mark it makes a clunk noise
Back to Top View babytitan's Profile Search for other posts by babytitan
getitshelley
Posted: Jun 06 2006 at 6:00pm | IP Logged Quote getitshelley
the servos makes it's air clunk noise at start cold its consistant. the noise from the cgove box or sounds like the glove box is what apears to be fluids i went to the dealership we traced it to the fluid container that is over near the firewal can't remenber what fluid daa stupid me, mine i can hear all the time if i really listen  my 2005 was really bad but my 2006 is alot more quite. i also have noticed most of the noises are more quite in my the 2006. i really love to drive my frontier do you
Back to Top View getitshelley's Profile Search for other posts by getitshelley
vq40de
U.S. - Mississippi
Posted: Jul 12 2006 at 4:54pm | IP Logged Quote vq40de
my 06 frontier when you get the engine under load and you give it enough gas to shift at 2500 rpm it starts with this rattling sound thoght it was exhaust shield but getting worse does anyone else have this problem.
Back to Top View vq40de's Profile Search for other posts by vq40de
4Point0Crew06
Posted: Jul 13 2006 at 12:16pm | IP Logged Quote 4Point0Crew06
vq40de, your problem sounds like excessive spark knock.
As far as exaust noises, I figured out its the cheap potmetal heat shields mounted to the exaust directly under the driver. Mine gives a metallic rattle every time I shut a door. I've crawled under there twice and beat on them a little, tried to move them just enough so maybe they'll shut up, and it works....no more noise when shutting a door, but the rattle returns after my next drive. That cheap, thin metal expands and contracts a lot with heat, and since its so thin, it's very noisy. That's where all your 'clicking' is coming from. The dealer isn't likely to do anything about the thermal expansion noises, as a lot of cars do this, but not as noisily...but I'm tempted to ask about the "claaaaaaaang" I'm getting when I shut a door.
Back to Top View 4Point0Crew06's Profile Search for other posts by 4Point0Crew06
vq40de
U.S. - Mississippi
Posted: Jul 13 2006 at 10:58pm | IP Logged Quote vq40de
what would cause spark knock and when you get under the truck by the oil pan you hear it good
chucknorris
Posted: Jul 14 2006 at 10:49pm | IP Logged Quote chucknorris
ive had my 06 frontier for about a month now and i have a metallic rattle sound coming from what seems to under the truck? ( i think ).  its not all the time but i hear this metal type clinking sound when i close my door or if im going over some rough roads.....not sure whats causing this but by reading some of the above suggestions / resolutions im gonna ride it out....not too sure to even bring it in since it doesnt hamper the drive....aside from the clinking here and there.  hopefully it isnt something bad though.
chuck norris doesnt sleep; he waits...
Back to Top View chucknorris's Profile Search for other posts by chucknorris
Posted: Jul 15 2006 at 11:31am | IP Logged Quote kcidmil
Easiest way to check it out... go underneath and push around on some items like your exhaust line, driveshaft... etc.  Just be careful on pushing sensors, the could easily break or be damaged.
You may find something as simple as your brake line is close to the exhaust line, and every time you close the door it shakes and hits it.  Don't know till you look.
Page of 2 Next >>
