eriscocoo Newbie
Posted: Mar 05 2012 at 11:28pm | IP Logged
Hello, does anyone know where the fuse for the ac/heater fan or blower is on an '07? I've checked the fuse panels and there are not any listings for it. a friend of mine and myself were installing a new set of headlights when one of the bulb holders caused the headlight fuse to blow and ever since then the fan hasn't worked. We replaced the fuse for the headlights and they work fine. Any suggestions?? Thanks!
Posted: Mar 06 2012 at 8:26pm | IP Logged
There is a fuse panel to the right of the lower glove box,
also fuses in the IPDM E/R(under the hood).
