crunkbait Newbie
Posted: Feb 21 2012 at 7:52pm | IP Logged
Please Advise. I just bought a 02 Frontier (Crewcab/Longbed/Off Road/AT/V6) with the front drive shaft out! Don't ask me why. AFter I bought it I reached down and grabbed the shaft connection point hanging out the back of the t-case and it felt as wobbly as a loose tooth! I think thats bad.
It looks like the axles unbolt from it and then its just three or four brackets and mounts right? I don't even have to remove the wheels, do I?
Also what else fits this truck as I starting looking around for one? other years and models?
thanks
virgin post!!!!!
Posted: Feb 22 2012 at 6:26am | IP Logged
welcome to the org.
wow talking about walking right into a project. Question,
is the yoke sticking out of the back of the t-case wobbly,
or just the u-joint. If just the u-joint is flopping
around you can replace just those. If it's the yoke,
you'll need to get the transfer case rebuilt or get a
replacement.
You can use a 01-03 frontier, and i'm not 100% sure, but i
believe the 01-03 Xterra used the same transfer case.
crunkbait Newbie
Posted: Feb 22 2012 at 8:19am | IP Logged
the u joint is on the shaft. the yoke is whats all wobbly. like beyond tcase rebuild wobbly.
so if its an easy drop down swap. i'll start calling the salvage yards.
