Subject Topic: replacing egr valve Post ReplyPost New Topic
sleepyzzz
U.S. - Arkansas
Posted: Apr 16 2006 at 11:25am | IP Logged Quote sleepyzzz
hi everyone.  i have a 2001 frontier and my service engine light came on.  taking it to a local shop, i was told that my egr valve was bad.  previously, i had added a can of 44-k to my gas tank, which my service man told me would clean the engine and bring back it's power.  the truck has 218,000 miles on it.  now i wonder if some of the carbon from the engine has come loose and clogged up the egr valve.  i added another can of cleaner, hoping that it might just break up the carbon in the egr valve.  today i took off the air cleaner and got to the egr valve, but couldn't get it off.  i was told to take it off and spray carb cleaner all in it.  the valve will move up and down with my fingers, so should i go ahead and buy another and have it installed?  any help would be appreciated.
Back to Top View sleepyzzz's Profile Search for other posts by sleepyzzz
gandl2123
Posted: May 11 2008 at 3:31pm | IP Logged Quote gandl2123
Wow, can't believe no one has answered you post...
The EGR Diaphram (the thing you moved up and down with you fingers) is spring controlled to keep it shut and seal off any exhaust gases from getting into the intake stream unless the engine rpm is right....running down the road etc...
Just because you can move the diaphram up and down does not mean that it does the same when the vacum is applied or that it is sealing off the exhaust gas when it is not being activated.
The best way to show if that is the problem is to take it off and seal the opening into the intake and then run it and see how she runs. If she runs great then that was your problem.
Just today I removed my EGR valve from my 98 Forntier and I blew into the pipe that comes from the manifold and I was able to blow a substantial amountof air past the valve when it should have sealed.  This is due to carbon build up on the valve faces or a piece of carbon trapped in the seat area???  I will try to fix it and work some WD-40 in there and get her sealing.  If that doesn't happen it is time for a new one.
Mr. Tripp
Augusta, GA
Back to Top View gandl2123's Profile Search for other posts by gandl2123
