Subject Topic: Master Brake Cylinder Post ReplyPost New Topic
Scamper
Posted: Jun 01 2011 at 6:33pm | IP Logged Quote Scamper
I'm trying to replace the master brake cylinder ("MBC") on my 2007 SE, V-6, 4WD, 6-speed manual with ABS.  The MBC has the standard electrical connector on the inboard side (i.e., towards the center of the enginge compartment), and then another electrical connector for the brake sensor on the bottom of the MBC.  All the parts web sites that I have been to carried only the MBC "without" brake sensor.
Does anyone know where I can locate a MBC?
Thnx.
Scamper
Back to Top View Scamper's Profile Search for other posts by Scamper
Posted: Jun 01 2011 at 8:12pm | IP Logged Quote frontierguy
Dealer. Why are you replacing it, just out of curiosity?
Scamper
Posted: Jun 13 2011 at 10:36pm | IP Logged Quote Scamper
Spongy brake pedal.  Have bled system, checked booster, etc.  - no joy.  Figure there's a problem with the M/C.
Actually have found one and installed it, but am now trying to find out if there's a bleed valve for the ABS controller.  So far, have not been able to locate it, and pedal still spongy (but better than before).
Scamper
Posted: Jun 14 2011 at 8:24pm | IP Logged Quote frontierguy
Trust me, they all feel spongy, but stop great! Bleeding
procedure is as follows: ignition off-disconnect ABS
controller or disconnect neg battery terminal-bleed RR-LF-
LR-RF in that order.
