Subject Topic: Humming sound going 40mph Post ReplyPost New Topic
ktsienna
U.S. - Hawaii
Posted: Feb 06 2011 at 2:48pm | IP Logged Quote ktsienna
I just started to notice a moderately loud hum going 30-45mph. The HUM is not noticable at any other speed. Is there a way to tell if it is the transmission or the wheel bearing?
Thanks,
2004 Nissan Frontier
4 cyl
103k miles
Back to Top View ktsienna's Profile Search for other posts by ktsienna
Posted: Feb 06 2011 at 6:39pm | IP Logged Quote frontierguy
Could be tires. Auto or man trans? Possible final drive,
does the noise lessen when you let off the throttle?
ktsienna
U.S. - Hawaii
Posted: Feb 08 2011 at 12:39am | IP Logged Quote ktsienna
It is an auto transmission. It does lessen the noise slightly when I lay off the throttle. I had new tires put on it 9 months ago.
Thanks for your insight.
4 cyl
103k miles
Posted: Feb 08 2011 at 8:17pm | IP Logged Quote frontierguy
If the sound lessens when you let off the throttle, it is
possibly a concern in the final drive unit(rear
differential).
ktsienna
U.S. - Hawaii
Posted: Feb 08 2011 at 11:39pm | IP Logged Quote ktsienna
Thanks for the information. I have a feeling you are correct. I really appreciate the help.
4 cyl
103k miles
