Posted: Jan 23 2011 at 10:02am | IP Logged
You really have waited too long on this. I agree with Frontier guy to some extent. Maybe what I would do is just drain the pan, replace what drains out, drive it for 2000 miles, repaet and then again. I think the 04 Frontiers took Matic D??? That is really the same as Dexron. But I would go to a dealer and buy the correct fluid.
I would NOT flush the trans at this point and don't let anyone talk you into that. After a few of the drain and fills, you might want to have the pan dropped and cleaned. This method should provide a gentle cleaning. I would expect the fluid you drain to be burned a dark brown. Watch the trans for signs of funny shifts, slippage or other unusual behavior. Crud that loosens can get into the valve body and clog up some of those small orifices or clog the cooler in the radiator.
