Subject Topic: new problem Post ReplyPost New Topic
03SE4DRCC
Posted: Jan 20 2011 at 12:39pm | IP Logged Quote 03SE4DRCC
ok i have posted on here already about my truck sputtering and stalling out. I changed out my plugs(expect for the #6 plug), wires, distrabtor cap. It started up and i got i parked at my apartement, but now when i run the codes it just gives me a the PO328 which is says is my knock sensor. Any thing you guys can think of that it could be.. one of my friends that is good with vechiles told me that i should change my timing belt.  And if you know anyway to get to that #6 plug would be of great help i had a hell of time getting just the new wire on there!
03 FRONITER CC 3.3 V6 / 160K MILES
Back to Top View 03SE4DRCC's Profile Search for other posts by 03SE4DRCC
Posted: Jan 20 2011 at 5:54pm | IP Logged Quote frontierguy
There used to be a tool in the tire changing kit that is
used to remove the #6 plug, not sure if the later odels
have it or not.
03SE4DRCC
Posted: Jan 24 2011 at 12:41pm | IP Logged Quote 03SE4DRCC
ended up getting a diagram someone posted on another forum, it took right at an hour to get it off and on, but it does help to have long arms and fingers for the job. Again thanks for the help, but i didnt see where there was an spark plug changing kit in my truck.. i bought it brand new and i never had one.
