Subject Topic: 2000 V6 Low idle stall out Post ReplyPost New Topic
bplummer
U.S. - North Carolina
Posted: Sep 30 2010 at 2:30pm | IP Logged Quote bplummer
I have a 5 speed, V6 Crew Cab.    The idle drops down real low when I push in the clutch, then "comes back" to normal.   It feels acts like it wants to stall now and then when it does this.
I changed the fuel filter 2 days ago when it started doing this - didn't help.
Any suggestions?  I'm preparing to replace the drivers side Cat converter; could this part being bad cause this issue?
Thanks.
Back to Top View bplummer's Profile Search for other posts by bplummer
bplummer
Posted: Sep 30 2010 at 3:34pm | IP Logged Quote bplummer
....Throttle Position Sensor???  The truck has a new : Distributor/Knock sensor....had a tune up about 2 years ago (new wires/plugs/cap..)
....maybe it's bad gas??
Posted: Oct 01 2010 at 4:58pm | IP Logged Quote frontierguy
Checking and/or adjusting the TPS is quite an involved process. Try cleaning the throttle blade and MAFS, be sure you are using a Genuine Nissan oil impregnated air filter.
bplummer
Posted: Oct 03 2010 at 4:00pm | IP Logged Quote bplummer
Where is the throttle blade?  Is the MAFS connected to the hose directly after the air filter, up top?
bplummer
Posted: Oct 03 2010 at 4:11pm | IP Logged Quote bplummer
"Duralast/Throttle Position Sensor"  - - - Changing this sensor is a detailed process?
Posted: Oct 06 2010 at 8:13pm | IP Logged Quote frontierguy
In all honesty, if you don't know, your vehicle needs professional help.
Posted: Oct 06 2010 at 8:15pm | IP Logged Quote frontierguy
Again,it is about a 14 step process to install, adjust, perform idle memory, etc. Best done at a competent dealer.
