Subject Topic: 2001 XE Frontier V-6 5 spd. clutch Post ReplyPost New Topic
surfahjammer
U.S. - Hawaii
Posted: Feb 08 2010 at 12:30am | IP Logged Quote surfahjammer
< =text/>_popupControl(); Hi all.  Just recently i've noticed once in a great while in 1st gear when I engage my clutch from a complete stop it sometimes causes the truck to jerk a few times before it smoothly accelerates normally.  When it does that if I let off the gas it'll stop jerking and take off normally again.  Other than that my truck runs perfect.  The clutch is strong it does'nt slip and can even chirp the tires in a couple gears.  Anyone know what's happening here?  Is this a problem?  Do I need to just adjust the clutch or something?  All advice welcome.
live to surf:) surf to live
Back to Top View surfahjammer's Profile Search for other posts by surfahjammer
Posted: Feb 08 2010 at 6:43pm | IP Logged Quote frontierguy
TPS concern possibly. Any check engine light??? Are you using a Genuine Nissan oil impregnated air filter????< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
2001FrontierXE
Posted: Feb 14 2010 at 1:10pm | IP Logged Quote 2001FrontierXE
I have the same problem, but only happens when the temp
outside is 50 degrees Fahrenheit or below. No check engine
light, and I use Fram Oil Filters to answer the question
posed to surfahjammer.
2001 Nissan Frontier King Cab XE 2.4 5spd airintake/cherrybombturbo
(past Nissan/Datsuns)
1970 PL521 1600
1994 Nissan Hardbody
1995 Nissan XE
Back to Top View 2001FrontierXE's Profile Search for other posts by 2001FrontierXE
Posted: Feb 14 2010 at 4:45pm | IP Logged Quote frontierguy
My concern is with the AIR FILTER not the oil filter.
2001FrontierXE
Posted: Feb 16 2010 at 8:06am | IP Logged Quote 2001FrontierXE
I must have had one to many beers when I read the original post.  Copy AIR FILTER.  Its an aftermarket Specter and is oil impregnated.
1970 PL521 1600
1995 Nissan XE
