Subject Topic: intermittent heat Post ReplyPost New Topic
s37shamus
Posted: Jan 31 2010 at 10:32am | IP Logged Quote s37shamus
2005 Frontier 4x4 Nismo V6  32k miles
intermittent heat from blower.  It will sometimes blow heat then turn cold.   If I switch fan off then on, sometimes this will bring heat back.  Also driver door side blower vent does not blow at all.  Also had intermittent A/c problem in summer where a/c would only turn on when blower in off position.
Any suggestions would be appriciated.
shamus
Back to Top View s37shamus's Profile Search for other posts by s37shamus
Posted: Jan 31 2010 at 3:08pm | IP Logged Quote frontierguy
Check coolant level in rad and over flow tank. Have seen rad failures causing cross contamination between ATF and coolant. With eng cool see if there is any signs of oil at the rad cap or floating on the coolant. Also check ATF for milky or dark color. The drivers upper vent can be manually opened or shut if that is the one you are talking about. Possible blower amp for the A/C concern????< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
