Subject Topic: Front tires rub on turn Post ReplyPost New Topic
milanoguy
Posted: Jan 09 2010 at 3:20pm | IP Logged Quote milanoguy
2002 Frontier XE 2WD, 2.4l. Newbie truck owner question: Truck came with 235/75 R15 tires on Nissan Alloys - oversize [recommended is 225/70 R15].  problem is that when slow speed turning [as in parking, etc] the tires rub against suspension [tension arm]. Is the best fix [other than going to correct tire size] putting in wheel spacers.  If I do then will I need longer wheel bolts.  Thanks for any insight
Back to Top View milanoguy's Profile Search for other posts by milanoguy
Boomer
Posted: Jan 10 2010 at 6:56am | IP Logged Quote Boomer
I would just go back to the right size tires.  Adding spacers will change the strain on your wheel bearings a little.  I am not a fan of doing that.  It is the same as changing the backspacing.
2007 Nissan Frontier SE 4X4
davidjbrady
Posted: Jan 10 2010 at 6:21pm | IP Logged Quote davidjbrady
I had a buddy of mine put in washers on the studs before putting the wheels back on, you are talking about 10mm wider tire a mere third of an inch, washers might work and most important of all, be sure to tighten the lug nuts to the proper torque.
08 Frontier CC, 4X4, LWB
Posted: Jan 10 2010 at 6:44pm | IP Logged Quote frontierguy
Like Boomer says, go with the tires, the washers are a backyard dangerous fix!!!!< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
