Subject Topic: No heat Post ReplyPost New Topic
capnflapper
U.S. - Georgia
Posted: Dec 24 2009 at 1:13pm | IP Logged Quote capnflapper
Have a 07 Frontier, 46,000 miles. I am not getting very much heat from my heater. No antifreeze leaks, temp does not seem to be up to par. Can only get about 160 degrees from radiator. Also appears to be now flow from the thermostat hose to the lower radiator. If the thermostat would not open, I believe I would have an overheat problem. Vehicle does not overheat. Runs great full power. But no heat!! Any advice? Ran vehicle w/o rad. cap to vent air, still no good.
capnflapper
Back to Top View capnflapper's Profile Search for other posts by capnflapper
Posted: Dec 24 2009 at 3:50pm | IP Logged Quote lakota
capnflapper
Welcome to the group!
Try this...  Drain the cooling system. Pull off the heater hoses and reverse flush the heater core with a garden hose and re install. Remember the garden hose will have more pressure than the heater core can stand! Be careful…
Happy Holidays
oldson20s
Posted: Dec 28 2009 at 12:40am | IP Logged Quote oldson20s
i was just reading it in the other forum, because im having the same issue. they said to keep filling up your radiator over fill tank. there might be air stuck in the heater core. i put some water/antifreeze in earlier tonight before i left. my heater got a little warmer while i was driving that it did before. ill put more in tomorrow and see what happens.im driving a 2001 frontier 2.4l extended cab with     204500miles on it. damn its bout time to change the oil again
Back to Top View oldson20s's Profile Search for other posts by oldson20s
Posted: Dec 29 2009 at 7:22pm | IP Logged Quote frontierguy
Thermostat may be stuck open. Is the coolant level OK in the rad and overflow tank???
< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
tedidit
Posted: Dec 31 2009 at 5:26am | IP Logged Quote tedidit
Had a similar problem with my 05 4.0L frontier. Added half a gallon of coolant to the overflow tank and got heat back. Was hoping not to turn it into a can of worms, easy fix worked this time...
Back to Top View tedidit's Profile Search for other posts by tedidit
oldson20s
Posted: Jan 04 2010 at 12:52am | IP Logged Quote oldson20s
seems like im still having the same problem as the original poster.the extra water in the overfill tank helped a little.  i had my water pump replaced a few months ago, did the thermostat at the same time. the guy that did this for me showed me that there was a difference between the two thermostats. and im thinking that the new one is opening way too soon. because the truck isnt getting cold at all. i might have to get a new thermostat and see if that does anything,
