Subject Topic: 1999 Frontier Automatic Transmission? Post ReplyPost New Topic
chastings92
Posted: Dec 09 2005 at 11:08am | IP Logged Quote chastings92
I have a 1999 Nissan Frontier 4X4 V-6 with an Automatic Transmisson.  It shifts from first to 2nd really hard and when it shifts into overdrive it shutters(Vibrates the whole truck).  Has anyone had any of these problems with theirs? Any information would be appreciated.  I also know there is a service bulletin for the Engine Valve Tap at start up.  Does anyone know how long they will take care of this problem?
Thanks
Back to Top View chastings92's Profile Search for other posts by chastings92
Posted: Dec 09 2005 at 4:53pm | IP Logged Quote kcidmil
If the vehicle has not received the service before, they will honor it.
For the tranny problem, sounds like your clutch discs are having problems... possibly low on ATF.
Posted: Dec 10 2005 at 1:26am | IP Logged Quote lakota
chastings92;
I also have a 1999 Nissan Frontier 4X4 V-6 with an Automatic Transmisson. Have you tried changing the Tranny fluid yet? I don't have a lot of miles on mine yet but I drained and refilled mine at 30,000 miles. I also installed an aftermarket cooler... Here are a couple of tips I copied from the Internet:
Drain it then carefully measure how much came out and replace with the exact same amount.. its pretty easy.
You can also do several drain and fills of the pan to get mostly new ATF in there. 4 drain and fills will get you to about 90% new ATF since each drain is 4qts and the total capacity is 8.75-9qts. Then just drain the pan every other oil change to keep the fluid in good shape.
Watch out for the pan bolts, spec is only around 4ft/lbs and they are easy to snap and crossthread.
Have a good one ;) and CUL..  lakota
chastings92
Posted: Dec 10 2005 at 7:50am | IP Logged Quote chastings92
Thanks guys.
sweetNlow
U.S. - Massachusetts
Posted: Jan 03 2006 at 3:50pm | IP Logged Quote sweetNlow
i got a 99 frontier AT, mines only a 2wd 2.4 but it also shifts hard into 2nd.  i looked into it i thought it was tranny problems also, but it's just the way the timing is set on the tranny to shift,  it's no big deal,  it's actually kinda cool, my truck can chirp 2nd with an automatic 4 banger!  :)
it's got da cool air!!!
Back to Top View sweetNlow's Profile Search for other posts by sweetNlow
Posted: Jan 03 2006 at 5:26pm | IP Logged Quote kcidmil
Mine did the same thing with the auto tranny.  Of course with the tires I had, mine would do more than just chirp the tires.  On the right road surface mine would roast for about 10 seconds.
sweetNlow
Posted: Jan 04 2006 at 11:53am | IP Logged Quote sweetNlow
oh ya of course it would, and it's the only truck i have ever heard of that would chirp 2nd with an auto 4cyl.  its pretty sweet
Posted: Jan 04 2006 at 5:06pm | IP Logged Quote lakota
Gentlemen;
... There are a few new drivers out there that don’t know that the rubber compound in the tires becomes hardened with heat cycles and age. As my factory installed (BFG Long Trails) became 4 years old they were so brittle I could hardly start to move with out the chirping. It was very impressive to the tinny boppers in the area.
... But in the rain they were absolutely dangerous even with a lot of tread left! I love my new BFG 31” ATs. I have to work a little bit to get a chirp now but at least I can stop if I need to.
Have a good one  and CUL.. lakota
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
‘99 Frontier Se KC 4x4 3.3 Auto LSD 1” lift BFG 31” ATs
Twenty two continual years owning Datsun-Nissan (and Jeep) cars & trucks
