Subject Topic: Frontier-Timing Issue after head rebuild Post ReplyPost New Topic
cali98
Posted: May 02 2009 at 11:46pm | IP Logged Quote cali98
I've got my 98 Frontier put back together and it will start for about 5 seconds and then stall.  I'm thinking I may have the lower chain off by a tooth.
The original lower timing chain only has 1 alignment mark on it.  How may links are there between the first mark and the second mark?
The upper cam sprockets have 2 marks per sprocket.  Does anyone have picture or procedure on how this should be timed?  The chain has 3 marks and I matched two of these marks with the outer cam marks.  The third mark I matched with the mark on the idler gear.
Any input would be appreciated.
Thanks for you help!
1998 Frontier 203k miles
-almost running
lower guide broke
bent intake valves
rebuilt cylinder head
Back to Top View cali98's Profile Search for other posts by cali98
