Subject Topic: bearing noise, automatic transmission Post ReplyPost New Topic
2000FrontierFLA
Posted: Mar 18 2009 at 7:08pm | IP Logged Quote 2000FrontierFLA
I'm at a little over 150,000 miles on my 2000.  I'm getting a bearing noise, 99% likely that it is coming from the transmission (torque converter).  So I'm at a decision point:
I've gotten a heck of a lot out of this truck, and it otherwise still runs like a dream, but it's only worth about $2,000, and I suspect a new transmission will set me back at least that much.
Has anyone replaced their transmission here?   I was thinking of just going to Nissan, since one of my local dealers will actually give a loaner vehicle for any major repair work you have done there.
I don't doubt I can get at least another 50,000 miles out of this truck, and a couple grand for a new transmission still works out cheaper than 2 years of new car payments.
The other route I could go...my mechanic says to just keep driving it until the bearing noise gets a lot louder, but I'm not real hot on the idea of getting stranded somewhere.
Your thoughts?  Your input?
2000 Frontier, 150,000 miles. It's not pretty, but it's paid for! 2.4 liter, automatic, 2WD
Back to Top View 2000FrontierFLA's Profile Search for other posts by 2000FrontierFLA
Posted: Mar 18 2009 at 7:31pm | IP Logged Quote frontierguy
2WD - 4WD - 4-6 cyl ???????  When does the noise occur???
2000FrontierFLA
Posted: Mar 18 2009 at 9:36pm | IP Logged Quote 2000FrontierFLA
4 cylinder, 2WD
You can hear it at idle, in or out of gear.   You can hear it up to 20 MPH, but it's probably still there, you just can't hear it over the tire and road noise.  But the transmission still shifts and responds normally.
We've ruled out the alternator & water pump.  It's not likely to be the power steering pump, since the noise is much more noticeable from lower in the engine.
