Posted: Mar 09 2009 at 12:30am | IP Logged
On my '06 is the oil guage, pressure or temp?
On start up, when the outside temp is below freezing the needle on the oil guage goes up as I accelerate, drops a bit when the tranny shifts. It levels off to normal at cruising speeds.
This only happens until the engine has warmed?
1.Regardless of which type of reading temp vs pressure, any idea on why the reading goes up under acceleration?
I'm running Mobil 1 5W30. I'm living in the Yukon so have had some -40C temps but this appears to happen even at just below freezing as well.
Hugh
'00 Audi S4 6sp
