Subject Topic: Radiator Change Post ReplyPost New Topic
BronzeSECrewCab
Posted: Dec 18 2008 at 4:09pm | IP Logged Quote BronzeSECrewCab
I have a 2001 SE Crew Cab.
Do I need to remove the front bumper in order to let the radiator free?
If anyone has any tips or a detailed walk through on changing the radiator I would appreciate if you post some helpful tips or steps
Hi guys
Back to Top View BronzeSECrewCab's Profile Search for other posts by BronzeSECrewCab
Posted: Dec 18 2008 at 7:28pm | IP Logged Quote frontierguy
No. The rad comes out the top. Remove lower eng cover, drain coolant, disconnect trans cooler hoses(if auto), disconnect coolant hoses, remove lower section of shroud, remove attaching brackets, lift out. It's a lot easier to do than to explain, basically one bolt at a time.
