Subject Topic: Check engine light- DTC- P0128 Post ReplyPost New Topic
ricky
Posted: Nov 27 2008 at 2:15am | IP Logged Quote ricky
I have a P0128 on my 2004 nissan frontier with 30000 miles. What are the possible causes of the code. i have already checked the coolant level and it is good. the truck has the 2.4 litre 4- cyl, and it is a 2-wheel drive model.
thank you
Back to Top View ricky's Profile Search for other posts by ricky
Posted: Nov 27 2008 at 8:08pm | IP Logged Quote frontierguy
P0128 is thermostat function code. Most likely you will need to replace the thermostat and verify coolant is at the proper concentration. I suggest using a geniune Nissan thermostat.
ricky
Posted: Nov 28 2008 at 12:46am | IP Logged Quote ricky
how do i check the thermostat.
