Subject Topic: P0456 code Post ReplyPost New Topic
pethia
Posted: Nov 08 2008 at 8:20pm | IP Logged Quote pethia
I have a P0456 code coming up.  I replaced the gas cap, but the code came back.  The other day, I filled the gas tank up all the way and the service engine light went out.  However, it came back on when the gas tank was 2/3 full.  Any thoughts appreciated.  2005 Frontier 4 cyl.
Back to Top View pethia's Profile Search for other posts by pethia
Posted: Nov 09 2008 at 8:09am | IP Logged Quote frontierguy
NTB07-059 says to replace the vent control valve and install a filter kit. If you drive on very dusty roads, you may want to consider replacing the canister also, seen a lot of canisters full of dirt.
pethia
Posted: Nov 09 2008 at 7:31pm | IP Logged Quote pethia
Now have a P0455 code.  I am wondering about the canister volume control solonoid.  Advice?
Posted: Nov 09 2008 at 9:13pm | IP Logged Quote frontierguy
P0455-P0456-P0442-P1446 are all included in the same tsb, replace the vcv and install filter kit. Again, check canister if vehicle is driven on dusty roads.
