Subject Topic: Tail Light Removal/Line-X Post ReplyPost New Topic
GKWJR
Posted: Oct 12 2008 at 2:01pm | IP Logged Quote GKWJR
Need to change a tail light bulb and the Line-X dealer covered up the bolts when he sprayed the bed? Use a butane mini-torch to heat the bolt head & soften the plastic. Alternately heat and scrub with a wire brush then use an X-acto knife to cut away and clean off the residual goop. Don't even bother to try a solvent, Line-X is tough stuff.
Ken
Back to Top View GKWJR's Profile Search for other posts by GKWJR
