Subject Topic: reset airbag light Post ReplyPost New Topic
he@dsh0t
Posted: Jul 08 2008 at 4:41pm | IP Logged Quote he@dsh0t
so i installed a new deck and now the airbag light is blinking.. how do i reset it? another thread says turn it on 30 times. i dont think thats working on my model. i have an 08 frontier.. anyone know how to reset the light?
Back to Top View he@dsh0t's Profile Search for other posts by he@dsh0t
dakeeper
Posted: Jul 16 2008 at 9:54pm | IP Logged Quote dakeeper
OK This works...
Turn ignition to run and wait for light to begin flashing..
Immediately turn ignition off..
Wait 7 seconds..
Do this 3 times total..
At the 4th try turn to run and wait for airbag light to flash slowly..
Start truck and let run 1 - 2 minutes..
Turn ignition off..
The next time you start truck the light should shut off after initial warning light check..
Back to Top View dakeeper's Profile Search for other posts by dakeeper
he@dsh0t
Posted: Jul 22 2008 at 8:56pm | IP Logged Quote he@dsh0t
still isnt working... anyone else???
dakeeper
Posted: Jul 22 2008 at 10:57pm | IP Logged Quote dakeeper
Sorry to hear it didn't work..  I got these instructions from Nissan service and used it on my friends 08 to turn off his light and worked fine.. The  7 sec time is pretty critical I was told... I tried it then had a friend call out the 7 secs on a watch to get it to work.. There are other posts with the same info here if ya do a search.. Make sure the plugs are all in and tight too.. If loose will not reset.. I have the service manual on disk and there is a way to access what is wrong with key combos if all else fails..
