Posted: Jun 26 2008 at 5:59am | IP Logged
I agree with Lakota. But here's a trick I have used very successfully for squealing belts for years. It has worked on friend's vehicles even when a dealer threw up their collective hands.
Get some SILICONE dielectric grease. DO NOT use petroleum based grease. Apply small babs on the ribbed side (or the V side) of the belt at about 6-10 locations, making sure it goes across all the ribs. Turn the engine on and let it idel for a minute. This will coat the inside of the belt and keep it from squealing. Don't put any on the ouside of a serpentine belt or the tensioner may slip past it's tension point!
