Subject Topic: Tailgate Adjustment Post ReplyPost New Topic
7sudden
U.S. - Alaska
Posted: May 31 2008 at 1:57pm | IP Logged Quote 7sudden
okay, complete newB question;
Just noticed that the left side of the tailgate on my 2008 Fronty is mis-aligned slightly.  (call me picky)
Can anyone take a minute and explain the easiest way to adjust this properly?
Back to Top View 7sudden's Profile Search for other posts by 7sudden
paris1
Posted: May 31 2008 at 2:48pm | IP Logged Quote paris1
Well it looks like you've got three choices. You could try adjusting the strike bolt on the bed (there usually is some provision for adjustment here). If that fails, you could see if there's any provision for adjustment in the latch assembly on the side of the tailgate. If all else fails, take it back to the dealer and let them worry about it. I had the same problem on a '98 Dakota and never could improve on it. I just learned to ignore it. I usually had much more serious problems to deal with on that truck anyway!
Back to Top View paris1's Profile Search for other posts by paris1
7sudden
U.S. - Alaska
Posted: May 31 2008 at 5:37pm | IP Logged Quote 7sudden
Thanks. I've give the strike bolt a try. It's minor, but I haven't learned to ignore it otherwise.
