Posted: Jun 06 2008 at 4:30pm | IP Logged
Referance the overheating post from lenny on May 24.
First off thanks for the responses.
I've owned the truck since new and have serviced the radiator with distilled water every 30k miles. It now has 135k. It may have some corrosion in it but I don't think it could have much with the service procedure I perform. As far as air in the system. when I fill the system I bleed it at the top of the block and than again after it reaches operating temp. It may still have air in it but the bleed procedure plus the number of times I've had the radiator cap off to eyeball the coolant level makes me think that is not the problem. However I'll bleed it again using the "rev the motor method". Also there are a few bugs on the AC condenser but no bent vans
According to the service manaual to check the fan clutch you spin it when cold and than again when hot. The manual says it should spin freely when cold and with some resisitance when hot. I'm not sure how one actually defines those things but this is what I observed. When the fan was cold and I turned the blades there was enough drag on the shaft that it would not move the blades unless I was pushing. When the fan was hot there was way less drag. Now, I woud think for the fan to pull more air threw the radiator there would be a good bit more drag when hot allowing the fan to "bite" more air. After coming to this conclusion, right or wrong, I replaced the fan clutch. Unfortunately the engine still gets hot and the new fan clutch exhibits the same cold and hot characteristics as the original!! Did I say I don't mind replacing parts as long as I know they are bad??!!!
So what say ye boys...stil hot in SC.
