Subject Topic: crap on ,or in my paint! Post ReplyPost New Topic
05blacknismo
U.S. - North Carolina
Posted: Oct 03 2005 at 6:20am | IP Logged Quote 05blacknismo
I`ve got a black 05  and the thing that`s bugging me now is something happend to a spot on the paint on the front fender ,it has a oilish type look to it as if there was tire dressing on the paint but I`ve washed and waxed and it`s still there!
Back to Top View 05blacknismo's Profile Search for other posts by 05blacknismo
MileHigh S/C
U.S. - Colorado
Posted: Oct 03 2005 at 8:57am | IP Logged Quote MileHigh S/C
I used to work for a Nissan dealership in Arizona, the white paint guard film from the factory, some times leaves a glue residue on the paint, have you tried a cleaner wax? Maquiers makes a great cleaner wax. You also could try Castrol Super Clean, spray it on dry, let it sit for a couple of minutes, lightly rub it and hose it off.  I use this stuff to take road tar off my truck.
If its what I think it is, one of these should take it off.
 Good luck.
You Ain't Got No Thing if it Ain't a Supercharged Thing!
'04 Frontier 4X4 S/C Crew Cab Long Bed
Nismo Cold Air Intake
Back to Top View MileHigh S/C's Profile Search for other posts by MileHigh S/C
AZLS1
Posted: Oct 03 2005 at 11:03am | IP Logged Quote AZLS1
There is also a TSB regarding tire dressings discoloring the paint.
Basically it says don't use them. and it is not covered under the warranty.
Back to Top View AZLS1's Profile Search for other posts by AZLS1 Visit AZLS1's Homepage
sweetNlow
U.S. - Massachusetts
Posted: Nov 11 2005 at 1:40pm | IP Logged Quote sweetNlow
i bet that happened when whoever it was that prepped it got it wet there and painted over it.  even the slightest bit of moisture will show through.  either that or someone got water on it while the paint was drying,  and it set in when it actually finished to dry
it's got da cool air!!!
Back to Top View sweetNlow's Profile Search for other posts by sweetNlow
