Subject Topic: Turning signals not working Post ReplyPost New Topic
neffboy
Posted: Mar 24 2008 at 9:37am | IP Logged Quote neffboy
I recently installed an aftermarket cd player in my 2004 Crew Cab Frontier and now the turning signals do not work. The emergency flashers work just fine. The stereo used the same hook ups so I know that I'm not missing any connections. Does anyone know why this is? I saw that others have had this same problem on other forums but no responses. Thank you.
Back to Top View neffboy's Profile Search for other posts by neffboy
mac87
Posted: Jan 06 2009 at 5:30pm | IP Logged Quote mac87
hey i got a friend with the same problem. did you find a solution? can't find anybody who knows what it is
Back to Top View mac87's Profile Search for other posts by mac87
mac87
Posted: Jan 11 2009 at 3:40pm | IP Logged Quote mac87
i would really like some help on this.
my friend has 2000 nissan frontier that had a aftermarket cd player installed in it and ater they installed it the blinkers quit working but the hassards still work any ideas im stumped and no one can tell me what it is i would like any help i can get thanks
thedave360
U.S. - Louisiana
Posted: Jan 12 2009 at 11:33pm | IP Logged Quote thedave360
Its weird that the hazards work and not the blinkers. I assume you disconnected the hazard switch to remove and install the radio. If its disconnected the blinkers won't work. Check the connection on the hazard switch, make sure its tight.
Shift_Your own gears
Baton Rouge, LA
'04 Frontier XE
2.4L 5speed
***MODS***
Flowmaster 40 Series Exhaust
APC Air Intake
Red Calipers & drums
4 Kenwood Speakers
mac87
Posted: Jan 13 2009 at 2:25pm | IP Logged Quote mac87
cool i'll try that. But if hassards work then it couldn't be connected right?
Posted: Jan 13 2009 at 8:06pm | IP Logged Quote kcidmil
refer to the other thread for something to check.
Tadder
U.S. - Hawaii
Posted: Jan 13 2009 at 10:23pm | IP Logged Quote Tadder
The deck might be grounding out.  So you may want to insulate your wires better.  And make sure no wires are touching any metal.
Back to Top View Tadder's Profile Search for other posts by Tadder
mac87
Posted: Jan 14 2009 at 9:09pm | IP Logged Quote mac87
on the wire harness for a 2000 nissan frontier the factory plug has no ground you have to round it your self for a aftermarket cd player correct?
mac87
Posted: Jan 17 2009 at 1:10pm | IP Logged Quote mac87
ok they got it fixed it was the hassard switch. thanks for the help. but i still dont see how that switch could be out and the hassards still work doesnt make since
