Subject Topic: Gas Overflow Post ReplyPost New Topic
MileHigh S/C
U.S. - Colorado
Posted: Sep 12 2005 at 10:16pm | IP Logged Quote MileHigh S/C
Hey I have a '04 Fronty, and everytime I fill it up no matter what gas station, the gas over flows out the neck, not just a little but a lot. Does anyone else have this problem? My Nissan dealer has already replaced the filler neck but that didn't help.  Since gas is SO cheap right now I really love seeing  3 bucks of mine going on the ground.
You Ain't Got No Thing if it Ain't a Supercharged Thing!
'04 Frontier 4X4 S/C Crew Cab Long Bed
Nismo Cold Air Intake
Back to Top View MileHigh S/C's Profile Search for other posts by MileHigh S/C
MileHigh S/C
U.S. - Colorado
Posted: Sep 23 2005 at 10:40pm | IP Logged Quote MileHigh S/C
Well to all those who read this and scratched their heads, the problem is solved.  My Nissan dealer Service Writer did a awsome job and never gave up on the problem. They at first thought the filler neck was pluged so they replaced that, problem still occured. Then they Dropped the Fuel tank and found that the old owner had submerged the back half the truck. Probably trying to launch a JetSki out of the bed. Anyways the valves inside were clogged with rust and mud so they replace the whole tank. If you live in Denver let me know I'll refer you to a service department that cares for once!
Posted: Sep 23 2005 at 11:22pm | IP Logged Quote lakota
MileHigh S/C
... I bought a used Chevy II wagon that the PO used for boat towing. Water had entered the rear differential and dang near ruined it. Check the axle breather valve. Check the rear end lube and if it’s ’murky’ looking dump it.
Have a good one ;) and CUL.. lakota
MileHigh S/C
U.S. - Colorado
Posted: Sep 24 2005 at 8:36am | IP Logged Quote MileHigh S/C
I ask  the service manager to pull the drain plug off the Rear Diff and see if it had water in it. They said the oil had been replaced and looked good with no water spots. Thanks
