Posted: Mar 09 2008 at 8:57am | IP Logged
Has anyone added guages to there 4.0 engines? Are the OEM gauges accurate?
I put mechanical gauges on my 94 ranger to verify oem gauges and the oil pressure was way off, I had good pressure but the gauge never really moved
from 50 psi to 20 psi. I was just wondering what would be needed to put them in line with the OEM gauge sender ports. ( I like numbers not C to H for temp)
these engines don't like being cooked with all that aluminum. Thanks
__________________ 2007 frontier V6 6spd crew cab bought 3/08 St Louis
