Subject Topic: Supercharger Problems? Post ReplyPost New Topic
Crosscheck
U.S. - Colorado
Posted: Nov 19 2007 at 3:18pm | IP Logged Quote Crosscheck
I have a 2002 Frontier S/C.
The supercharger has a rattle-type of noise in it.
At first, I thought one of the idler bearings for the Serpentine
belt were going bad but, after listening closer with a stethoscope,
I found the noise coming from the 'Charger. Is this a common issue
and what is the fix?
Thank you.
Back to Top View Crosscheck's Profile Search for other posts by Crosscheck
nbaldanza
U.S. - Kentucky
Posted: May 22 2008 at 1:54pm | IP Logged Quote nbaldanza
I HAVE AN 02 ALSO AND MINE IS MAKING THE SAME NOISE I TOOK IT TO A TRUSTED MECHANIC AND HE SAID IT SOUNDS LIKE IT NEED OIL IN THE SUPERCHARGER I CALLED THE NISSAN DEALERSHIP AND THEY SAID THE MOTOR OIL RUNS IN TO THE SUPERCHARGER AND LUBRICATES IT SO I AM GOING HOME TONIGHT AND TRYING TO BREAK THE PLUG LOOSE ON THE SUPERCHARGER AND CHECK FOR MY SELF
Back to Top View nbaldanza's Profile Search for other posts by nbaldanza
nbaldanza
U.S. - Kentucky
Posted: May 23 2008 at 3:04pm | IP Logged Quote nbaldanza
FOUND OUT THAT THE MOTOR DOES NOT SUPPLY OIL TO THE SUPERCHARGER YOU HAVE TO UNDO THE PLUG AND FILL IT UP YOUR SELF THE GUY I TALKED TO AT THE NISSAN DEALER SHIP SAID THE WOULD PUT A HEAVY THICK OIT IN IT LIKE 80W-90 OR CLOSE TO THAT AND THAT SHOULD STOP THE LOUD NOISE YOU HEAR
hsckris
U.S. - North Carolina
Posted: May 25 2008 at 9:18am | IP Logged Quote hsckris
Its also possible that you could need a rebuild.  These superchargers have been known to need servicing at as little as 80k.
06 Nissan Frontier KC SE 4x4.
03 Ford Focus ZX3.
Chris6744
Posted: May 28 2008 at 11:25am | IP Logged Quote Chris6744
try to service it. superchargers take a very special oil that you need to buy at nissan. wear gloves because if you get the oil on ur hands it smells for days
2007 nismo 4x4 cc (red)
3IN LIFT,TOYO MT'S,
Boise ,ID
Posted: Jun 10 2008 at 8:25pm | IP Logged Quote frontierguy
Thank you.
lassification:
ECO4-011 Reference:
NTB04-083 Date:
July 14, 2004 2001-2004 FRONTIER AND XTERRA;
SUPERCHARGER NOISE AT IDLE AND LACK OF POWER APPLIED VEHICLES:
2001 - 2004 Frontier (D22) equipped with supercharger.
2002 - 2004 Xterra (WD22) equipped with supercharger.
IF YOU CONFIRM:
^ The supercharger makes a rattle/grinding type noise at Idle, and
^ The engine has reduced power while driving.
ACTION:
a. Review the supercharger information in this bulletin.
b. If your incident is not caused by "park knock" as described in this bulletin:
^ Go to ASIST for further diagnostic information
NOTE :DO NOT REPLACE THE SUPERCHARGER FOR A SPARK KNOCK INCIDENT.
SUPERCHARGER INFORMATION
Premium fuel is required
^ The Supercharged (VG33) V-6 engine used in the 2001-2004 D22 Frontier and the 2002-2004 WD22 Xterra requires Premium Fuel.
^ If premium fuel is not used, the engine may experience "park knock" during acceleration or under heavy loads.
^ If spark knock is detected by the "knock sensor", the ECM will put the supercharger into bypass (fail-safe) mode.
^ The supercharger will make a rattle/grinding type noise at idle when it is in "fail safe".
^ Also, the engine will have reduced power if driven in "fail safe".
Supercharger Bypass Valve
^ The bypass valve limits boost pressure from the supercharger when the system is in fail-safe.
< =":Zoom('/all/PRO~V60286547~C39887~R0~OB0~P2R0H~N/0/86372027 /89377758/89377833/110844307/
34853741/
34850750/42063452/119615480/108883910/108646547',
 1, 1088, 692, 'ZoomWin', CAPTION108646547, 'NONE', HIGHNONE);" method="post"> < value="Zoom" ="submit">
< =":SizedForPrint('/all/PRO~V60286547~C39887~R0~OB0~P2R0X~
N/0/86372027/89377758/89377833/110844307/34853741/34850750/
42063452/119615480/108883910/108646547', 1, 650, 413, 'ZoomWin', CAPTION108646547, 'NONE', HIGHNONE);" method="post"> < value="Sized for Print" ="submit">
^ In fail-safe, the internal bypass valve will remain mostly closed (see Figure 1).
^ After the key is turned OFF the ECM will reset and restore the boost solenoid function.
The bypass valve will function normally, and the rattle/grinding type noise will be eliminated.
34853741/34850750/42063452/119615480/108883910/107283044', 1, 1072, 121, 'ZoomWin', CAPTION107283044, 'NONE', HIGHNONE);" method="post"> < value="Zoom" ="submit">
osccean23
U.S. - Nevada
Posted: Jul 01 2009 at 2:34pm | IP Logged Quote osccean23
 i  have  the  same  problem   with  o2  nissan  frontier  sc   it  was  making  rattling  noise  it  was  under  warranty   so  they  replced  it   i  asked  the dealer  about  the  oil  they  say  they  dont  sell it    i  dont  know  about   gear oil  however  thres  a  member  in  our  group  knows  where  to buy  it  ,chris6744     let  us  know  chris  , have  great  day  fellas
riding ridin
Back to Top View osccean23's Profile Search for other posts by osccean23
ergomoto
Posted: Feb 22 2010 at 2:41am | IP Logged Quote ergomoto
I see this is an old thread with occasional posts.  I too now have the same "failed bearing" noise from my '03 SC, and am away on a trip with the truck.  I've always run High Octane and have not changed the pulley size.  Curious about this oil topic -if only to get the truck home.  Assumed it was going to take a rebuild and some luck to get the chance to do it at home.
Mark S/C
1965 Datsun 1300 520 Pickup
2003 Nissan Frontier S/C SE Crew Cab Std Bed
Is that what you wanted it to look like?
Back to Top View ergomoto's Profile Search for other posts by ergomoto Visit ergomoto's Homepage
