Subject Topic: Adding Automatic headlights Post ReplyPost New Topic
terraroxa
Posted: Nov 11 2007 at 9:22am | IP Logged Quote terraroxa
I have a 2005 frontier 4x4 nismo that HAS NOT an automatic headlights
device.
Is anybody knows how toi nsttal one?
Back to Top View terraroxa's Profile Search for other posts by terraroxa
Maxbaby
Canada
Posted: Nov 13 2007 at 12:55am | IP Logged Quote Maxbaby
Can't give you installation instructions but I did read thru the manual for my 2004... If you download the 2005 manual, you should be able to follow thru to see what you need.
There's a Daytime Running Light module, which in my case is apparently on the passenger side front wheelwell area inside the engine compartment.  I would think that if your wiring harness has the connector for this component, you might be able to plug it in and with maybe a few other connections, it should be good to go.  I can't say for sure, but often the wiring harnasses on U.S. models are the same as Canadian models... extra pieces are either connected or not at the factory depending on where the vehicle is going to end up.
2004 XE Crewcab 4X4
2002 Hyundai Santa Fe
1993 Volvo 850 GLT
Back to Top View Maxbaby's Profile Search for other posts by Maxbaby
Lemoninspector
Posted: Jan 11 2008 at 7:31pm | IP Logged Quote Lemoninspector
You will need the Headlamp switch with the Auto feature on it and also the photo cell that mounts into the middle of the dash. Courtesy parts has the switch for the 2005s with the auto feature and also the foglamp switch.
ASE Certified Master Technician
2007 Crew Cab 4.0L Auto. White.
Back to Top View Lemoninspector's Profile Search for other posts by Lemoninspector
