Subject Topic: clutch & transfercase issues Post ReplyPost New Topic
armyman20057
Iraq
Posted: Aug 28 2007 at 7:12pm | IP Logged Quote armyman20057
hey whats up guys, i  had some issues with my 06 frontier 4x4. I was just giving u guys a heads up. I thought that i burnt my clutch out on my truck, hard to do but i do offroad everyday. well anyways i called nissan they said $936 to have it replaced. mainly cause its a 4x4 and the transfer case is there on the transmission and all that mess. well come fo find out that i had a leak, my front seal in my transfer case  right where the front driveshaft hooks into the case. well the seal broke so bad that in a few days all my fluid leaked out.(i park my truck in grass) causing lots of extra pressure on my clutch and flywheel, causing my clutch to go out..... all and all it all got covered because the leak caused the damage. Make sure you (P.M.C.S) your truck thats at an army term for preventive maintance checks and service, look at ur undercarage and inspect everthing once a month or everythime u go wheelin, we do pmcs every mondays on our humvees, so make a routine...
Back to Top View armyman20057's Profile Search for other posts by armyman20057
EB_05_NISMO
U.S. - Connecticut
Posted: Sep 23 2007 at 5:46pm | IP Logged Quote EB_05_NISMO
Thanks for the info!
2005 Electric Blue Nismo King Cab 6spd 4x4
Back to Top View EB_05_NISMO's Profile Search for other posts by EB_05_NISMO
