Subject Topic: Suspension NOISES Post ReplyPost New Topic
jms311
Posted: Aug 12 2007 at 2:39pm | IP Logged Quote jms311
I have a 2007 frontier crew cab with 5000 miles on it.  It has been to the dealer several times for a rear suspension problem.  Whenever I go over a hard bounce the rear suspension seems very loose and chattery.  Does anyone else have this problem or can anyone advise me what to do because right now the dealership does not know what to do ????
Back to Top View jms311's Profile Search for other posts by jms311
redfin
Posted: Aug 28 2007 at 6:52am | IP Logged Quote redfin
My 2007 was the same way. The delaer loaded up the leaf springs with chasis grease and the noises went away.
Back to Top View redfin's Profile Search for other posts by redfin
Boomer
Posted: Aug 28 2007 at 1:28pm | IP Logged Quote Boomer
It is best not to grease leaf springs as the grease collects grit and can wear the springs.  Far better to put teflon buttons or sheets between the leaves.  My 2007 has teflon buttons installed from the factory.  If you feel a lube is needed, try some WD-40.  This is not sticky like grease and will tell you if friction between the leaves is the problem.
jbraden
Posted: Sep 12 2007 at 8:26pm | IP Logged Quote jbraden
I just had my 06 Frontier in for suspension squeak/rattle.  Noise turned out to be hood and fenders squeaking.  Dealer tightened entire dog house and noise is gone.
Hope this helps and my noises almost caused me to trade mine.  Dealer said there is a lot of body flex in crew cab.
Back to Top View jbraden's Profile Search for other posts by jbraden
