Subject Topic: 2001 failed Smog Post ReplyPost New Topic
madolive3
Posted: Jun 30 2007 at 1:18am | IP Logged Quote madolive3
 Check engine light is on. It's Code P0420, Catalyst system Efficiency Below Threshold, (bank one). But the levels of HC and co2 passed and were very low. I failed because of the light.  It's a 2001 XE 4 cylinder auto with about 108000 miles.    There are some small leaks in the welds between the o2 sensor and the cat.   I also can't find the Bank one o2 sensor in the FSM....Any help would be greatly appreciated
Back to Top View madolive3's Profile Search for other posts by madolive3
shadow0289
Posted: Jul 08 2007 at 8:37pm | IP Logged Quote shadow0289
You only have a 4 cylinder so you only have one bank. the 1 sensor is before the catalyst, and the 2 sensor is after the catalyst or catalytic convertor.
Back to Top View shadow0289's Profile Search for other posts by shadow0289
