Subject Topic: Weird A/C problem Post ReplyPost New Topic
Dman
Posted: May 08 2007 at 7:36pm | IP Logged Quote Dman
Hello everyone, just bought a Nissan Frontier 2006 4x4 with 34000km on it, love the truck but I just discovered something weird with the A/C.  It only will work if I have the fan speed set to 2, and only seems to blow cold air out when I am driving above 80km.  Is this normal, am I just not using the A/C correctly or is it broken in some way?
Back to Top View Dman's Profile Search for other posts by Dman
Dman
Posted: May 10 2007 at 12:04pm | IP Logged Quote Dman
Well took it to the dealship, found out it was a blown fan motor resistor, so if anyone else has this problem thats what the cause was.
Posted: May 10 2007 at 3:17pm | IP Logged Quote lakota
Dman;
Thanks for the up-date about the A/C problem... and...
Welcome to the Frontier group!!!...
There was a time when some people got rich buy providing a better product at a lower price.Now they get rich by ripping us off and paying off the politicians. Can you spell DEREGULATION
pgpd
Posted: May 14 2007 at 3:03am | IP Logged Quote pgpd
Back to Top View pgpd's Profile Search for other posts by pgpd
pgpd
Posted: May 14 2007 at 3:06am | IP Logged Quote pgpd
I have 01... four door... my A/C is taking longer and longer to get cold enough to chill out the inside of the car. It feels like it is just blowing outside temp air inside but eventually kicks in to blow slightly cold air inside. No where nearly as cold as my Acura blows...
Once the engine is turned off, a hissing noise is heard for a few more minutes the stops.
Any Ideas??
Posted: May 14 2007 at 7:24am | IP Logged Quote kcidmil
Sounds to me like your A/C system has a slight leak.  NOT from the hissing noise though.  That is typical as the system pressure is equalizing.  But from the fact it takes longer and longer to get cold air.
