Posted: Mar 21 2007 at 6:44pm | IP Logged
There are so many points for the referigerant to escape. It could very well be leaking in the AC pump internally, though usually you get an oil mess. Plus with so many points that are hard to get a tester to, you'll be scratching your head.
I never found Nissan's truck AC to be all that great anyway.
Too get the best possible track down. Take your grill off, and remove your glove box. This will allow almost unrestricted access to the condensor and evaporator. Also... are they using a Sniffer, or dye tester? Sniffers won't detect anything if they're set too low.
